1 - 20 of 30 Posts
PHONE NUMBER: (352) 745-8074 - This is my cell, if I don't answer, then I'm in class (9:20am-3:00pm M-F)
EMAIL: [email protected]
PAYMENT PREFERENCE: Paypal (+3%) - [email protected], Money Order, Cash
Massive sale here guys, as I gear up for a full build - besides, wife is tired of tripping over these parts!
All items are + S/H
I will ship internationally.
I will start boxing these items up tonight!
ITEM: Stock Accordian Hose
PRICE: $20+s/h
DESCRIPTION: Soft, pliable stock accordian hose with no cracks.
PIC: http://members.cox.net/~doward/Supra/Sale/accordian.JPG
ITEM: Painted 3000 Pipe
PRICE: $5+s/h
DESCRIPTION: Stock 3000 pipe, cleaned and painted.
PIC: http://members.cox.net/~doward/Supra/Sale/3000paint.JPG
ITEM: Stock plastic fender pipe
PRICE: $5+s/h
DESCRIPTION: Does not leak, came from an '88 Turbo
PIC: http://members.cox.net/~doward/Supra/Sale/fenderpipe.JPG
ITEM: Stock Exhaust Manifold
PRICE: $30+s/h
DESCRIPTION: This is the manifold I just took off my own car. It had been painted with 500 degree paint, which wasn't enough, so it's a little dirty. No leaks or cracks.
PIC: http://members.cox.net/~doward/Supra/Sale/stockmani.JPG
ITEM: Stock Intercooler
PRICE: $35+s/h
DESCRIPTION: Stock Intercooler, no leaks (everything that came off my car had been pressure tested prior to removal) - some slightly bent fins, but works perfect.
PIC: http://members.cox.net/~doward/Supra/Sale/stockIC.JPG
ITEM: Stock CT26 turbine section
PRICE: $20+s/h
DESCRIPTION: Stock CT26 turbine section, that I sandblasted out. Wastegate door opens smoothly. Normal cracking (only 2 small ones) in the wastegate port.
PIC: http://members.cox.net/~doward/Supra/Sale/turbinesection.JPG
ITEM: Stock Head Shield Cover
PRICE: $10+s/h
DESCRIPTION: Stock head shield cover. If you are missing yours BUY THIS - I recorded a difference in intake air temps of 20-30 degrees when romping on it, without this shield vs with the shield.
PIC: http://members.cox.net/~doward/Supra/Sale/turboheatshield.JPG
ITEM: Stock CT26 oil lines
PRICE: $10+s/h
DESCRIPTION: Stock CT26 oil lines. Feed and drain, not clogged with crap. Not bent, either - very good condition.
PIC: http://members.cox.net/~doward/Supra/Sale/oillines.JPG
ITEM: Pre '89 Aux Radiator Fan.
PRICE: $10+s/h
DESCRIPTION: Same bolt pattern on the motor as the 89+ if yours is bad. If you don't have it, get it!
PIC: http://members.cox.net/~doward/Supra/Sale/fan.JPG
ITEM: Pre '89 Moulding
PRICE: $5+s/h EACH
DESCRIPTION: Stock pre '89 moulding pieces - very good condition.
PIC: http://members.cox.net/~doward/Supra/Sale/moulding.JPG
ITEM: More Pre '89 Moulding I found
PRICE: $5+s/h EACH
DESCRIPTION: Yep, here's some more I found.
PIC: http://members.cox.net/~doward/Supra/Sale/moretrim.JPG
ITEM: Stock 4" speaker boxes
PRICE: $5+s/h
DESCRIPTION: Stock 4" speaker boxes!
PIC: http://members.cox.net/~doward/Supra/Sale/speakerbox.JPG
ITEM: Box o' Junk
PRICE: $5 each
DESCRIPTION: Tell me if you want anything from this box. Blue wires, antenna motor, CPS sold
PIC: http://members.cox.net/~doward/Supra/Sale/stuff.JPG
ITEM: 3" GM MAF for MAF-T Setup
PRICE: $35+s/h
DESCRIPTION: Brand new reman'd (cardone) 3" GM MAF - LT1 calibration.
PIC: http://members.cox.net/~doward/Supra/Sale/3inchmaf.JPG
ITEM: Stock Fuel Rail/FPR/440s
PRICE: $50+s/h
DESCRIPTION: I've got a brand new set of 550s going in, so my fuel setup is for sale!
PIC: http://members.cox.net/~doward/Supra/Sale/440srail.JPG
ITEM: Zeitronix ZT-2 Wideband Controller
PRICE: $80+s/h
DESCRIPTION:This is a BRAND NEW ZT-2 wideband controller. I bought a 2nd one for my Accord, and I've since sold it. You will need the LSU Bosch Wideband, Signal harness, and Oxygen sensor harness. This is your chance to have a BRAND NEW ZT-2 for $200 (Regularly, this setup is $280)
PIC: http://members.cox.net/~doward/Supra/Sale/zt2.JPG
ITEM: Stock BOV
PRICE: $10+s/h
DESCRIPTION:Here we have a stock BOV, no leaks, works good.
PIC: http://members.cox.net/~doward/Supra/Sale/stockbov.JPG
ITEM: 2" Silicone Connectors
PRICE: $5+s/h for all 3
DESCRIPTION: 2" silicone connectors, perfect if you are making your own hard pipes for the stock turbo/IC!
PIC: http://members.cox.net/~doward/Supra/Sale/2insilicone.JPG
Discussion Starter #2 (Edited)
ITEM: 38mm 2bolt Wastegate
PRICE: $75+s/h
DESCRIPTION: Tial style, has it on a turbo V6 project I used to have, coupled with an ebay T70 - 14psi spring in it, and it works perfectly! I've got another flange for it around here somewhere, I'll toss in with it
PIC: http://members.cox.net/~doward/Supra/Sale/38mmwg.JPG
ITEM: 1991 Toyota 7MGE block/rods/pistons
PRICE: $50+s/h
DESCRIPTION: Pulled from a Cressida, see my build thread for pics of how the motor was cared for before I got it - as far as I'm concerned, the block was just a crate to hold my 7M crankshaft! Complete shortblock, minus the crank and oil pump. Front sump pan included. Never been bored - virgin block for your build. This IS a late model block, with the stronger mains and casting. As for the power steering pump? I have no use for it - call it a freebie :D
PIC: http://members.cox.net/~doward/Supra/Sale/7mge.JPG
ITEM: 1991 Toyota 7MGE Head/Cams/intake/stock fuel rail/injectors
PRICE: $125+s/h
DESCRIPTION: You can take it all for $125+, or I'll split it up if someone only wants part of it. I want it gone! Motor had no signs of a BHG, btw.
PIC: http://members.cox.net/~doward/Supra/Sale/7mhead.JPG
ITEM: Middle of the lights from a '88 Turbo
PRICE: $15+s/h
DESCRIPTION: It's paint code 167, very clean and straight. I went JDM '89+, so I don't need this!
PIC: http://members.cox.net/~doward/Supra/Sale/88midtail.JPG
ITEM: '88 Taillights
PRICE: $30+s/h FOR BOTH
DESCRIPTION: No gouges, no cracks, no breaks.
PIC: http://members.cox.net/~doward/Supra/Sale/88tails.JPG
ITEM: 3" AEM DryFlow filter + 3" AFM replacement pipe
PRICE: $35+s/h
DESCRIPTION: DAMN NEAR NEW AEM dry flow 3" filter + pipe to replace the AFM, for you MAFT-Pro guys!
PIC: http://members.cox.net/~doward/Supra/Sale/aemdryflow.JPG
ITEM: Partially Polished AFM housing
PRICE: $10+s/h
DESCRIPTION: Partially polished AFM housing I found in the boneyard - thought maybe someone could use it!
PIC: http://members.cox.net/~doward/Supra/Sale/afmhousing.JPG
ITEM: Random Items!
PRICE: $5+s/h
DESCRIPTION: I want this stuff gone! Anything you see here, $5! Hoses have no leaks, and still soft and pliable!
PIC: http://members.cox.net/~doward/Supra/Sale/pileocrap.JPG
ITEM: 3" SS Turbo Elbow
PRICE: $85+s/h
DESCRIPTION: 3" Stainless steel turbo elbow - works great, flat flanges - even will include a new steel CT26 outlet gasket.
PIC: http://members.cox.net/~doward/Supra/Sale/sselbow.JPG
ITEM: Cold Start Injector
PRICE: $15+s/h
DESCRIPTION: Clean, ohm tested, ready to roll!
PIC: http://members.cox.net/~doward/Supra/Sale/csi.JPG
ITEM: CSI hose
PRICE: $5+s/h
DESCRIPTION: Doesn't leak! What more do you want from it?
PIC: http://members.cox.net/~doward/Supra/Sale/csihose.JPG
I STILL have more to get up later.
Yes, I will combine shipping.
Remember 3% paypal fee.
Any other questions, just call me.
John
See first post.
Sorry guys, all those pics were getting to be too much. I've linked them all, since there are so many of them. mods, if that is a problem, please contact me.
Don't be afraid to throw offers my way. I want this stuff GONE ASAP.
Not right now, no - but I have one tomorrow.
Discussion Starter #9
That was supposed to say I *MIGHT* have one tomorrow :p
That said, which part do you need? Bolts to the head, or has the hose going to the radiator? Or both?
BMM
The stock CT26 comes with no WG?
BTW, I'm gonna get that paypal sent out this afternoon when I get home.
Discussion Starter #11
Do you need one? If so, I have a spare I will toss in with it.
BMM
Yeah if it works well. Also, how "minimal" is the shaft play. The one I'm replacing is rediculous, I'm suprised it has made it this far.
Discussion Starter #13
'minimal' is - well, let me go measure it ;)
Discussion Starter #14
Axial play I've measured to be .089mm, and radial to be .124mm, so it's still within spec.
No drag as it spins, and in no way contacts the housing.
BMM
thanks for taking the time to measure it for me.. Mine is at about .25" in and out and around .175" back and forth.. Time for a new one. I will get that paypal sent to ya tomorrow for the ct26 and the WG.
Discussion Starter #16
Whoa! That's a lotta play :D
Discussion Starter #17
Boltz - your PM box is full, man! $28 if you pay through paypal, shipped, though.
Discussion Starter #18
Added ZT-2 wideband controller.
I want the turbo. I am out to sea until the 26th if you can hold on to it until then.
I have cash and can send paypal as soon as I am back.
Discussion Starter #20
First come, first serve. I actually haven't had any interest in the 57 trim, so it's possible it will be here still :)
1 - 20 of 30 Posts
