1 - 10 of 10 Posts
Just got my downpipe & Superdragger from "Sully" and they look great. Time for an install.
Originally I was planning on just taking it to a local shop and having them do it, but I figured, I'd ask how difficult it would be to do it myself.
Any thoughts? I couldn't find any writups when I searched.
-E
BPU is so 1997
It's really easy to do the downpipe, especially if the upper DP bolts have been removed before. If you have an impact gun, it's a breeze to do. If you are doing with handtools, get some long extensions and a breaker bar. Before you have at the bolts, soak them with some PB Blaster, it will help loosen them up a lot. It's not hard to do at all. Just might take some strong arms to bust the bolts loose.
Single Turbo
^agreed
Simple for the most part. I did my whole DP and exhaust install. Alot of shops wont put a catless DP on for you.
-Pete
Hardtopper
Ascari_2 said:
Do it yourself, you'll feel the pleasure of knowing you did it.
EXACTALLY!!! I JUST did mine this weekend,.. along with complee Defi BF Gauges and control unit, FJO etc... and I feel soo good. Its def a feel of pride knowing you did ur own work.
Also for the top 3 bolts on the DP forget theimpart gun, i had best luck with a braker bar and swivil
best of luck
1 - 10 of 10 Posts
