Downpipes????
767 Views 4 Replies 2 Participants Last post by  Brittany
What are the differences between downpipes? I saw a stainless steel Blitz dp for sale. Are dp's supposed to eliminate both cats or just the first cat?
Thanks,
Downpipe Specs
Hello,
A 3" downpipe is sufficient. The downpipe doesn't need to be any larger, as it gives little extra effect and will scrape on the road too easily. The downpipe removes BOTH cats and results in huge horsepower increases of 45-55rwhp. You must be careful, if you have an intake and exhaust, as the car may hit 15psi and invoke the fuel cut limiter which is designed to shut down the engine to protect against overboost. We have had problems with this at about 6300rpm. In the event the car does hit fuel cut, the ECU needs to be reset and a GReddy Boost Cut Controller installed. Please note too, that if you have a OBD II vehicle, removing the cats will result in a constant-on check engine light, which has no effect.:)
The guy that was selling the Blitz downpipe told me that his only eliminated the first cat. I guess there are differences in the types of dp's. Thanks for your response.
The HKS downpipe only eliminates the first cat also.
RMM is the most common downpipe. It eliminates both. I don't understand why someone would want to eliminate just the first cat.
Brittany
