feeding your habit
don't do it there. You can take it off the line that is on the IC side of the butterfly.......... there is a line there that runs to the PS pump modulator. You can tee into that and see IC piping pressure. There is a smaller line from the same modulator that runs to the manifold side of the TB, you don't want that.
Do not try to drill and tap your IC piping, it won't hold the threads reliably.
-M
-M[/QUOTE
I like this idea. Where is the ps pump modulator? It works just as good as tapping the ic pipe?
feeding your habit
-M[/QUOTE
looking at the TB where the air comes in, from the trac motor side... on the bottom there are 3 nipples... two are for coolant (to heat the TB, believe it or not) and one is a pressure source for the PS pump modulator. The modulator is a round block on the PS pump and it has two lines. One runs to this side of the TB, the other runs to a nipple on the manifold side of the TB. You want to tee into the line that runs to the FMIC side of the TB, not the MANI side of the TB.
-M
