1 - 14 of 14 Posts
Anybody got an idea where to find a replacement center bearing? I haven't run across it in the usual auto parts stores...is this a bend over and lube it item from the dealer?
thanks...
isnt it called a carrier bearing?
Addicted to Boost
i ahd gotten a used one, and i dont think its ging to last much longer than a few more months if that
MKIV intervention needed
why not get a new one from curt at elmhurst? they cant be that much...or can they?
yeah thats me!
check out the one-piece at jawsgear.com
i have one that i will be installing when im done with my swap.
looks like a great piece.
Can't you just measure the length and get the existing d-shaft extended?
I've seen it done all the time to extra cab d-shaft that has a two piece d-shaft. Maybe the flange needs to be cut off and weld to the lengthen piece? Or is it a slip yoke type?
yeah thats me!
yea, then you have 14 y/o+ U-joints... my center bearing was sloppy and my u-joints were shot.
mine are ~20 years old
Just go with the one piece aluminum driveshaft and never look back. Probably ONE of the best mods i have done to my car yet.
Why do you say this?
I'm just curious as I'm considering doing it for a cleaner component and reduced rotating weight.
Do you notice anything?
You will notice a huge difference trust me. Just gets up and goes a hell of a lot quicker.
1 - 14 of 14 Posts
