1 - 4 of 4 Posts
Canada, Eh?
yes, i did search.
my center-bearing is making sounds, so it looks like ill need to replace it or get a onepeice driveshaft in the near future.
a freind suggested to me to get my stock driveshaft cut apart and welded into a single peice unit. take out the center joint, weld a tube in, have it balanced. has anyone ever done this? is it safe? i need to save my pennies for a new clutch right now, so an aluminum 1-peice is out of the question on my budget. a local shop will mod the stocker for about 1 hours labor.
ƒ=1/2π(√k/m)
A remanufactured... or new driveshaft will work just fine, no need for an expensive one piece.
IMO: As long as you're not launching the bejesus out of it, and HP lower that 500, you shouldn't need a one piece.
You can actually go to a good mechanic, or machine shop and have them "repair" your carrier bearing, or the universals and you'll be golden.
As for making you're own one piece, I wouldn't risk it, and personally I wouldn't trust MYSELF to make one, so I don't know about you or your friends. :lol:
BUT , if you have the resources I say give it a whirl... let us know how it worked out.
Good luck.,
Beat the hell outta tu!!
Unfortunately most aftermarket 1 piece driveshafts (aluminum or CF) are priced over $400 these days. For that price you are much better off just replacing the center bearing with a new piece.
1 - 4 of 4 Posts
