1 - 9 of 9 Posts
My fan is f'd unfortunately so i am looking into some electric fans.
I searched around for a while and now i just have a few questions...
I noticed that people were saying the flex-a-lite fans were unreliable. I live in Georgia and it gets EXTREMELY hot here durring the summer. I'd rather not spend 300 dollars on something that isnt going to prevent my car from overheating.
With that said, i was looking into the dsm and contour fans...
For whatever reason people seem to recommend the both of them a lot. Has anyone ever had trouble with either of them as far as not being efficient enough to cool the car? (overheating)
Also i would like to know specifically what year dsms i am pulling these fans from if i decide to go with them.
Any sort of write up/install procedure/pics would be cool as i am trying to assess whether or not to replace the stock fan clutch or just go electric.
After reading what i read i am totally turned off on the F-A-L's
Thanks in advance for the help/flaming... whichever it may be
Later,
Cramerizking
i think the dsm fans are gonna be some of the best fans you can get that fit over our raditor for its price (around 50 from a junkyard). I ran them for like 5 months in like 110 degree summer florida weather...the temp guage never winked
Ok that's what i wanted to hear. How exactly do you have them wired up? I've seen a few people do the fans with a toggle switch and so on... I'd rather not.
whatever you guys think is the best method though...
oh and what dsm did you pull yours off of?
was it last gen? 2nd to last gen?
also... turbo... na?
Thanks a lot for your help
· Buddy thought I had a NA
Later,
Cramerizking
man don't get the talon fans there junk the best fan to get off car from the wreaker is the ford torus fan's they flow the most and will do all your cooling needs plus they are 2 speed fan
viperjames said:
yes im thinking of this aswell.. i might just get the taurus one.. what year and model of taurus and how would u hook up the the fan... have auto or toggle ?
just hook it up on relay and then use trigger for the secound speed of the fan since it will kill your altnator cause it flow like motor fucker for power then the flex fans as well on it's max speed
and it from a 92 v6
· MKIII Owner and Dam proud
I removed my fan and went with dual hayden electric fans. Two 12" will fit (barely). SO i went with hayden 10"
Kept the motor plenty cool.
· Back to boosting!
I used one 16 and one 14 from jegs...63 bux a piece...I only have the 16 in right now but it seems to do plenty fine. Had to get em cause the ole stocker kicked a blade into my rad...not cool...
1 - 9 of 9 Posts
