hey guys.
i'm modified my stock rail to run dual feeds (mk3 7m-gte).
Now, my stock fpr port interfere's with my tps.
My only option is to move the fpr feed back (after the #1 cylinder.)
here are some pics
in this picture, the blue fitting is my feed. The port that was block was originally my fpr, was going to be my feed which is directly over the # 1 injector.
The blue fitting is now after the # 1 injector.
the individual who had this setup before said his # 1 cylinder went dead, faulty injector (venom).
do you think it has to do with the feed being after the # 1 cylinder?
the way i see it, is if i have a feed coming from one end, and another feed from the other with a return in the middle, the whole rail must fill up with whatever pressure the fpr is set to, then bleed it off.
anyone see a problem with this?
feed after the # 1 cylinder?
return in the middle?
might want to move this to the MKIII section :)
i figure i would get more action here.
probably more mkiv guys running dual feed then mk3's
well they use a different rail than the 7m does.
As for te sock FPR port. If you attach a fitting there and then run a hose to the fpr it will alleviate your problem.
but to answer your question.
The previous owners problem. Venom injectors. Case closed ;)
they might use a different rail, but dual feed is dual feed.
so their input is valuable.
the problem is i cannot attach a fitting in the stock fpr port for the first feed.
i had to move it back i.e, past the # 1 cylinder.
