1 - 14 of 14 Posts
I got my Sound Performance Fuel Kit the other day but I never got any directions with it. When I searched the forums, I never really got any how to's either. Either way, being Audi Tech for almost 3 I thought for sure I could manage.
I spent about 2 hours making sure the pumps are installed as good as I can get them...but I took some pictures just to see what people think. If anyone has a dual pump setup that uses the stocker feed and a -8 secondary, please tell me if this is how you have yours in there.
Also, Larry told me to use the 2 stock 12+ and GRD wires as 12+ wires...question is, where in the harness to the pumps (outbound of the hanger) do you cut into to install the relays? Anyone know?
Pictures:
Justin
I dunno, I didn't think the ones that came with the Walbo's were stainless but I could be wrong. The 2 large ones that hold the pumps together aren't, I guess I didn't give it much thought. I guess I should get a batter way of putting them together, but Larry just told me to just some band clamps.
Justin
The clamps are fine.everything look ok.Use the factory trigger from the fuel ecu to one of the pumps.With that same wire use a relay to trigger the other pump.
jam98tt,
Do you have a step by step on relay wiring for twin pumps like this? I searched but I couldn't really find anything. I know normal relay wiring, but I just need to know where and what to tap. Thanks man!
Justin
I was going to tap Pin #1 as my "trigger" wire to the relay's. I understood this as being the best wire to tap signal because it's from the ECU/Fuel pump Relay. Here is how I want it wired:
I have two pumps and two relays. I have both relays grounded at the chasis at the center rear of the back. I have 2 4g fused wires right off the battery as the constant 12+ feed to the relays. I have the positive wire of each relay sent to the positive wires of the pumps. The pumps have they're own ded. ground. The only thing I didn't do yet is the "trigger" from the relays. and going from what I have gathered here, the fuel pump ECU PIN #1 is the best wire to tap for the relay "trigger". Do I have this right?
Justin
Spencer
Fuel pump ECU is where you get the trigger, use a voltmeter to check which pin it is.. The ECU primes the pumps for about a couple secs right before you start the, so you should see 12v when you turn the key for a sec.
Discussion Starter · #12 ·
Larry,
I acutally figured it out tonight with a meter. BTW, I have a factory computer. If you plug in the fuel pump ECU and check pin #2 with a meter you will find that it will send a 2 second 12v signal to the pump as soon as the key is on, and then stop. Then, while cranking/running, it continues to send out the 12v signal till the engine is shut off. I wanted to have it this way instead of a switched power source because of I'd rather not have the pumps running at full bore till the engine is started/running and for saftey reasons. As long as the engine isn't running, wired this way, the pumps aren't.
Justin
Spencer
you got it right!
I learned that I have to wait for the pump to fully prime the system before starting the car or it wont start... You can hear the walbros priming the system, and I wait till there done to start it up or it will just stall out.
1 - 14 of 14 Posts
