The theoretical advantage of the dual feed rail is taht there would be a more uniform distribution of fuel among cylinders, since fluid pressure losses would be less.
I know that the big dogs do not worry about that stuff for about 700 HP or less, but do not know at what point they would worry for bigger injectors - and power levels.
If there is a problem, I do not think that injector duty cycle would reveal it; these things look at aggregate parameters. If something goes wrong, one would expect that the cylinders on the return side of the rail would be the lean ones.
I would think that if there is a problem, detonation would come up, and the ECU would pull timing, and that might be a better parameter to monitor.
That much said, I think that we all are going on reasonable, yet empirically untested theories.
All the best
