1 - 3 of 3 Posts
My Greddy Profec B Spec solenoid (dual) does not control boost anymore and I don't know how it works to fix it. This is the original black B Spec, no the B spec II. When this boost controller worked in the past, it was awesome and stable.
Does anyone know of a good aftermarket dual solenoid boost unit I can get to replace this or a good aftermarket Dual solenoid that will control boost with AEM EMS v1? (The greddy controller unit appears to work fine, but the dual solenoid part leaks uncontrollably)
Cwtt,
Thanks for your reply. Since my Greddy Profec B Spec boost controller is already wired in and setup, will my Greddy boost controller be able to control this dual Mac solenoid valve setup?:
The voltmeter was showing the Greddy Profec B Spec boost controller was outputting a 12 volt signal to the solenoid unit. Given that the voltage doesn’t change when I turn the knobs, is my assumption correct that it’s a pulsed signal of some kind (pwm)?
251158
251159
251160
251161
1 - 3 of 3 Posts
