The problem is that when you use the battery the pumps are seeing alternator voltage. It is unregulated. The pumps can see over voltage or under voltage. Not real healthy for the pumps as they can see as much as 14v at times. Do we really need this much voltage at cruising? No!!
The stock ECU regulates the voltage across the pump terminals. With the walbros, you can use the stock 14awg wiring from the fuel ECU to the connector. I re-pinned the bracket assy with 12 awg although it probably wasn't needed. 14awg wire is rated for 28 amps alone in open air. When bundled with additional wires the rating drops some.
Here is a link for the difference in current draw between the walbro and denso
As you can see, the walbros draw almost half the current as the stockers.
The stock fuel ECU uses 9v at crusing and only at higher rpms does it give the pumps 12v. This preserves fuel pump life and reduces noise. I have no idea why people run the walbros off the battery and overkill the wire with 12awg or even 10 awg. Very silly to me. And yes, I know Lar with SP has an EE degree, and so do I
I have had the walbros running off the the stock fuel ECU for a year now with no issues at all. You can see that I have no tip issues or AFR issues at all. From viewing
this thread and observing my FJO graphs you can see there are no problems. I have made back-to-back hard pulls and got out of the car and felt the connectors and wiring. Not even warm.
