Good numbers given you have an auto and lose an additional 28-30% wheel horse power most high BPU guys on a 6speeds run around 420rwhp and -15% on your auto that’s 417rwhp. Your in good shape, but my only concern is you running on pump gas at that PSI you should be running at least 100-103 octane. I posted Phil’s post on this topic under.
This ratio is highly dependent on the ecu that you're running (i.e. the timing curve). With the oem ecu (and no timing piggybacks), a 'ballpark' starting point is to use a roughly 1:1 ratio above 14psi and 91 octane. Here is a VERY ROUGH guesstimate table to start with (octane=(r+m)/2*). Be sure to monitor/log your knock to confirm/verify:
Boost(PSI)__Octane ((R+M)/2)
----------__-----------------
14____________91
15____________92
16____________93
17____________94
18____________95
19____________96
20____________97
21____________98
22____________99
23____________100
24____________101
25____________102
26____________103
27____________104
28____________105
29____________106
30____________107
31____________108
32____________109
33____________110
34____________111
35____________112
36____________113
37____________114
38____________115
39____________116
40____________117
41____________118
42____________119
43____________120
FYI: Here's an example of how to calculate the 'net' octane if you mix fuels: 2 gallons of 93 octane pump gas with 6 gallons of 117 octane race fuel: ((2x93)+(6x117))/8 = 111 'net' octane.
Standard disclaimer: As always, ymmv.
* Do not calculate octane based on RON. Use only (R+M)/2, or preferrably MON.
