Do you just clamp to it Larry, or do you need a physical hard connection to the conductor?green long wire inside of the ignitor connector.
Most dynojets just clamp around it and pick up the signal inductively.Do you just clamp to it Larry, or do you need a physical hard connection to the conductor?
I'm in the process of making a custom harness for the engine, and if a physical connection to the conductor is required, I'm thinking about splicing the wire to a lug, and putting a cap on it. For easy access.
If just clamping, I can just leave portion of that wire exposed and not wrap that wire.
They dyno measures horsepower and if you don't know the RPM's you can't derive the torque. Keep in mind that HP and TQ are always locked in by the relationship:...What does it mean if you are loosing signal for the trq?
Dynos measure torque, not horsepower. The equation is right, but that means it calculates horsepower from variables it knows (torque and RPM).They dyno measures horsepower and if you don't know the RPM's you can't derive the torque. Keep in mind that HP and TQ are always locked in by the relationship:
