1 - 10 of 10 Posts
JZA70 448 rwhp everyday
Whats up, well i went to the dyno a while back, and made 236 hp, and 256 ft/lbs of torque at 3500 rpm, then hit violent fuel cut in 4th gear. #s are sae corrected,it was done a 1320 chassis fab where we had a supra meet a while ago, but i wasnt there for the meet. Anyguesses on what ill make once i get fuel cut and my smokey twins fixed? MOds in sig.
~scott
you got pics of the graph?
no scanner...basically i went up to 3500 everytime and shut it down because of fuel cut. It just seems kinda high compaired to other twins graphs. Runs were done on a cold night. Afs were 11.5 once boost came on.
~scott
~scott
Scott, we had the same weired things happen to us when we were at 1320.
I have installed a SAFCII and 550 going in soon and then I'll have a before and after tuning runs to see how accurate the 1320 dyno was.
Seems like a lot of guys had weired AF readings that day...
my AF readings were totally normal, and were the exact same as my own AEM wideband. It just seems like thats alot of power at 3500 rpm.
~scott
Not so boring anymore
dont run so much boost :eek:
Something doesn't add up.. hp=(torque X rpm)/5252
so your hp = 170 with 256 torque at 3500...
Discussion Starter #9
cant turn the boost down, i disconnected the boost controller, and it still hits fuel cut, i also have the SAFCII but it has 0 corrections, basically its just a gauge for now so how would it make me loose power? 170 hp @3500 rpm is in the expected area for a stock twin 1j correct?
~scott
seems pretty good looking at other peoples graphs..
1 - 10 of 10 Posts
