email it to me and ill put it up for you!
Don't understand the 1.1 bar part,why weren't you able to boost more and also why didn't they look into that problemsupra6spd said:I dyno'ed yesterday at AAM.
I'd like some of you tech guys to let me know what you think.
The chart has Max power 380RWHP (378.8) and it also shows the air fuel (wide band O2)
Here's what I used:
94 TT 6spd
93 pump gas
RPS stage III clutch w/ lightened flywheel
HKS intake/ SSBOV
AEM Cam Gear -4 exhaust
BCC
RMM downpipe
HKS exhaust
MBC
Greddy 60mm Boost guage....ONLY HIT 1.1 BAR ????
The guys at AAM said I could get a good 20-30RWHP just by adding and tunning a S-AFC ?????????
I NEED 400 to the wheels. The S-AFC will do that, right? Also, I don't need the VPC, I can just hook up the S-AFC and lean it out, right?
yasir said:
Don't understand the 1.1 bar part,why weren't you able to boost more and also why didn't they look into that problemDid you use the race gas ? Also from your A/F ratio curve i see you are running way too rich (around 10.7 at 4800 and then a spike to 11.2 and then back to below 10.0:1 which i think could cause you to loose some power. Ideally your A/F ratio curve should have stayed linear and also between 11.5:1-12.2:1.Someone correct me if i'm wrong
Yasir
