21 - 24 of 24 Posts
255 is the width of the tire in millimeters. 45 is the sidewall height in millimeters, ZR is the speed rating 149+, and 17 is the size rim the tire will fit on. 285-40/ZR18 front and 315-35/ZR18 rear is pretty much the widest tire you can fit under the car. :D You'll have to roll the inside of the fenders though. Or take out some bolt I hear for the front's. It doen't change the appearance or hurt the car.:)
Supra OG
You're wrong about the 2nd number, it's not the sidewall height in mm, it's the aspect ratio.... see the link below:
http://www.tirerack.com/tires/tiretech/size.htm
Andi
21 - 24 of 24 Posts
