Is it possible with lightly pull up on the E-Brake and not have your brake lights turn on when you want to slow down and not let anybody behind you see that you are slowing down? And if you can how?
Pulling the ebrake shouldn't turn on your rear brake lights period. If you wanted you could wire a switch on the power lines going to the brakes and be able to switch them off. Or just unplug the lights at the connector-But unless you want to be rearended or are trying to make a getaway I don't see why you'd want to do any of the above
