I bought a few additional harnesses with my e-manage... injector, and ignition.
the injector harness has 6 wires for injectors 1-6 to tap into the ECU.
the ecu, from what i saw on the TSRM has 3 pins for the injectors, having two injectors per pin. do i simply tie two of the wires together coming off the emanage and splice into the ECU?
for example, if the ecu is.. Pin 1: 1&2 Pin 2: 3&4 Pin 3: 5&6
would I tie the wires out of the emanage for injectors 1 and 2 together and solder them into pin 1 of the ECU?
if that doesn't make sence, i'll try and revise
Question two.
the ignition harness has 12 pins... Ch. 1-6 in and out.
I've read what i have avaliable, but i havnt found out what i hook these upto? Obviously the ECU, but what?
Question two.
