1 - 19 of 19 Posts
Interior had grey leather seats, new style gauge cluster, new style tail lights. What part of the ecu harness should I look at? The part that color of the connectors that connect to the ecu?
If you want I can go take pics of certain parts and you guys can let me know which part of the year it is. That would be really cool
Discussion Starter #13
The pin count of the ECU connectors says everything (26-16-22).
Late ECU......
So is what this guy is saying correct? I'm just trying to make sure because after searching around for a while it seems that everyone's got different opinions and answers. I believe you cuz you've helped me out a lot in the past with issues so thank you.
Discussion Starter #16
Joe, are you going to document the neo install?
Finished and hooked it up. It turned out fine. I'll do a write up tomorrow. I took a few pictures of the connections because that's basically all you have to do. Wasn't too hard
Discussion Starter #17
Update: I played around w the neo and I went from having a terrible, nasty misfire and lean idle to having a perfect idle. I upped fuel at 500rpm 44% and wow I got a perfect idle now finally. This is really cool
1 - 19 of 19 Posts
