1 - 11 of 11 Posts
REVTECHRACING.COM
for those wanting to fit 28"s in the rear it s easy if useng the rx7 rims which have a 6 1/2 backspacing. 1st shave and not roll your rear lips and for extra clearance ih ave koni shocks and i rasied the perch up 1/2 which wasnt needed but did so to make sure.i only have konis and tien lowering springs in the car which is just a 1.2 drop to begin with. the only issue is to get the rim/tires on the car to bolt on u must deflate down to like 8 psi due to the suspension hangs down on a a jack and hits the plastic pieces on both sides. once its lowered on the tire it all centers out. even with about 500 lbs. of fat people bounceing in the rear it dosent touch the tire. the tire tucks into the wheel well nicely. hopefully this will answer some peoples questions on a 28" m/t et street slick fitment.. my searches found nothing thats why i posted this for future information. thanks to jaynite also for the help on this tire fitment.
Bad Karma Supra
Nice! -glad you got your tire issue sorted out...hope this gets you the gearing you want for the traps.
See you at E-Town,
Jay
REVTECHRACING.COM
yes, hopefully itll get me passed the 1000' mark. my clutch will feel the wrath of this 28 though and 60' may be down. ill be there sunday for survival series 1 and 2night to run the nova a few times before the gamblers races.
its a slow auto...
Austrian Supra said:
Why is it that the 28X11,5X16 uses a 8" wheel, when the 26X11,5X16 use 10" wheels ??
my guess would be because its actully got more tread width then the 28x11.5.. so with the wider tread and less sidewall if you stuffed it on a 8 inch wheel it would probably pull the tire in and round the tire(pull the tread from flat to slightly rounded) and effect its performance...thats just a guess on my part though.. for a good answer you could always call them and ask:) it could be a typographical error on there site too..
3793 26X11.50-16LT
M5
24
10.0 (wheel width)
9552
10.8
9.7
26.2
82
3794
27X10.50-16LT
M5
20
8 (wheel width)
9552
10.4
8.7
27.0
85
3796
28X11.50-16LT
M5
24
8 (wheel width)
9552
10.7
8.7
28.0
6 speed
you think the 275/55/16 M and H drag radial would fit on our cars with the rx7 wheels? i have tein flexs if that matters. no rolled fender though.
M and H drag radial 275/55R16
Tread Width: 8.8"
Section Width: 10.9"
Diameter: 28.0"
Circumference: 88.0"
Rim Size: 9.0"
1 - 11 of 11 Posts
