Does anyone know where to find PW2 on an AEM Infinity 506 ECU? Here's what I'm talking about: https://www.aemelectronics.com/files...noid%20Kit.pdf. It's for installing an AEM EBC. I need a key on power source and PW2.. I don't have any instructions or pinouts for my ECU.
Ok, I’m going to share what I’ve found out so far because this should have been easier with a p&p harness, and anyone trying to install an electric boost controller might find this helpful.
So the Boomslang harness was supposed to have a handy little adapter labeled “Boost”. After assuring them mine does not, I opened up my harness to find there was never anything pinned for a boost controller. So since PW2 wasn’t doing anything for me in researching, I found Boomslang’s pin-out. Low and behold, in the dark green highlight C1 42 shows where boost control goes. As you can see in my harness, nothing is there (circled in red). I will now have to research what size these connector pins are so I can run a wire there. And I still need to determine where a good key on power source is, but working on it. I would like them both pinned in for a clean look.
Can I just splice into one of the wires coming out that are labeled "12v supply" or will that mess with the system that specific wire is for? Like C1-63?
If anyone is familiar with the infinity ECU, this is pin C1-42 highlighted in red. I am looking for another pin for a key on power source. But I can’t find a simple explanation of what each pin is. Any suggestions on what other pin to use? And if there is already something pinned there, is it ok to splice into it?
Finally found AEM's real schematic. According to it, C1-63 is the main power source supplied by the relay when key is on. So this should solve my question. So for future reference, an electronic boost controller is connected to C1-42 and C1-63.
