1 - 3 of 3 Posts
I have the new Blitz SBC-ID and I had a shop hook it up. They did something wrong since I can't boost past 7 psi when it is on. When i have it off though i can easily hit 20psi on a cold day. What is wrong. The guys over at NEMKIV.com said some hoses were hooked up wrong. Has anyone had this problem and if so, which hoses are connected wrong? I'm hoping this is a quick fix wgere I can just switch up a couple hoses.
Look at the article about the Blitz DSBC installation on www.mkiv.com and you can see how the hoses are supposed to be fitted. Also check whether the SBC is set to ACTUATOR and not WASTEGATE (presuming you are on stock twins).
Flavio
1 - 3 of 3 Posts
