I usually drive my car in Economy mode. There is a place I have to enter the freeway each morning and sometimes I will floor it to make a gap. When I do this, once I get into the higher rev ranges the engine will cut out as the turbo overspools. I know where it does this so I can just relax the pedal slightly, let it upshift and then press on the gas. Recently, I pushed in the PWR button and have been driving in the less efficient mode. This morning when I floored it the turbo never over spooled or cut out, accelerating smoothly all the way from zero to eighty. I thought that ECO vs PWR merely changed shift points. Clearly that is not the case, though I had also assumed that PWR would supply more fuel. Since more fuel = more exhaust, it was my guess that this would make it more likely to overspool, not less. The exact opposite happened.
What am I not understanding here?
Thanks as always for the education.
Do you have a boost gauge installed? If so, how much boost is showing when it hits this 'cut out?'
I suspect this has nothing to do with the transmission, and is in fact boost cut. You will hit boost cut at a lower boost level than most other 7M-GTE's because of the BC 264 cams you have installed. Bigger cams = more airflow at a given boost pressure.
Since boost cut is done by AFM reading, you're likely to hit boost cut at a significantly lower boost pressure with your setup.
Calling it 'turbo overspool' is a misnomer at best, because there's no 'spool' value for a turbo, it's not an empirical measurement of any kind. You can over-speed the CHRA itself (see my avatar for what that looks like) and that usually happens one of two ways:
-A boost leak that's just big enough to force significantly higher CHRA rpm to compensate for the boost leak and maintain targeted boost, this will usually also have noticeably more lag than it should.
-Targeting too high of a boost pressure at higher Density Altitude (empirical measurement of how the air gets thinner at higher physical elevations) - thinner air needs more turbine/compressor wheel rpm to move the same mass of air. This is how I nuked several stock CT26's while trying to run 14-15psi with fuel system changes and piggybacks.
In both cases, you'll see additional lag and reduced power, but you won't hit any direct 'boost cut' or hiccup sorts of events from the engine. At least, until the CHRA itself fails and the turbo looks like my avatar, in which case you'll suddenly have zero boost and likely a cloud of oil smoke coming out of the exhaust.
