Has anybody tried using the 7M ECT in conjuction with a stand alone ECU? I know the ECT requires a few signals from the ECU such as overdrive, but I have never experimented with anything else on that.
Doesn't the ECT require a signal from the TPS as well?The signals that the ECT needs are actually split off in the wire harness, I have a AEM, the only thing needed was to wire in a relay for the converter clutch, the AEM controls lockup, the ECT still controls the shifts.
Did you find this to be better than the AEM controlling shifting?The signals that the ECT needs are actually split off in the wire harness, I have a AEM, the only thing needed was to wire in a relay for the converter clutch, the AEM controls lockup, the ECT still controls the shifts.
I am going to use the 2JZ-GE ECU/harness and was considering the 1JZ-GTE auto tranny, until now....So for my conclusion is, as long as you have a TPS, and a speed signal from the tranny or the guage cluster, the ECT is a stand alone unit.
