1 - 3 of 3 Posts
Hey guys and gals. I recently installed the ecu master black into my 1990 mk3 7mgte which is pretty much stock and am looking for a good base tune. It will not fire as is even with the base map provided. Found some info and changed what I could but still no go. Any info would be a great help thanks.
Did you verify physical timing matches software timing?
I was able to figure out the settings from a video by Rapid jz and then loaded the base fuel map and she's alive again buts thanks for the reply!
1 - 3 of 3 Posts
