1 - 20 of 30 Posts
I've located all this, but does anyone know the numbers for the US-spec TT Auto 96-98 Supra ECUs?
Aristo ECU Part Number:
- 89661-35060 (91-93)
- 89661-30870 (93-97)
Supra ECU Part Numbers (Auto, J-Spec, NA):
- 89661-14600 (93-97)
- 89661-14810 (97-99)
Supra ECU Part Numbers (Auto, J-Spec, TT):
- 89661-14490 (9305-9310)
- 89661-14491 (9310-9605)
Supra ECU Part Numbers (5Spd, J-Spec, NA):
- 89661-14610 (only number listed)
Supra ECU Part Numbers (6Spd, J-Spec, TT):
- 89661-14500 (9305-9310)
- 89661-14501 (9310-9605)
- 89661-14770 (9605-9709)
- 89661-14830 (9709-)
Aristo ECU (JZS16#)
- 89661-3A470 (9708-0007)
- 89666-30180 (0007-)
The ECU part number depends on the age of the car.
2JZ-GTE engine
jzs=Aristo
89661-30510 = JZS147..Q Oct 91 - Aug 93
89661-30750 = JZS147..Q Aug 93 - Aug 95
89661-30880 = JZS147..Q Jul 94 - Feb 95
89661-3A180 = JZS147..Q Aug 95 on
2JZ-GTE engine
89661-30560 = JZS147..V Oct 91 - Aug 93
89661-30870 = JZS147..V Aug 93 on
All the US Spec numbers appear to be missing, actually. Noted!
Supra ECU Part Numbers (6-speed, US Spec, TT):
- 89661-14520 (93.5-95)
Aristo ECU (JZS16#)
2JZ-GTE engine
jzs=Aristo
2JZ-GTE engine
Figured i would jump here with my question.
I need to know how to tell the difference between California ECU's and normal ECU's.
I have 2 non turbo cars and i think this may be my issue with one of them but not the other. Just want to clear it up as to know which one is what for the ecu's.
ส็็็็็็&
89661-14560 = USDM NA Automatic Cali Spec 05/1993 - 06/1996
89661-14580 = USDM NA Automatic 05/1993 - 06/1996
89661-14570 = USDM NA 5spd Cali Spec 05/1993 - 06/1996
89661-14590 = USDM NA 5spd 05/1993 - 06/1996
I have a 24321 that's plugged up now what is that for?
Okay after some research I think I found my issue I'm using a sc300 5spd ecu for California spec
ส็็็็็็&
thats a SC300 ECU
89661-24321 = USDM JZZ31 5spd Cali Spec 01/1992 - 07/1993
Okay last one my auto supra now is using a
24350 what is this for?
Discussion Starter · #11 · (Edited)
This is a list of ECUs designed to run the 2JZ-GE and 2JZ-GTE engines. Ultimately I’d like to have a complete list compiled eventually if we can. Thank you to everyone that has contributed.
SUPRA MKIV
USDM
Supra ECU Part Numbers (Auto, USDM, NA-Cali)
- 89661-14560 05/1993 - 06/1996
Supra ECU Part Numbers (Auto, USDM, NA)
- 89661-14580 05/1993 - 06/1996
Supra ECU Part Numbers (5spd, USDM, NA-Cali)
- 89661-14570 05/1993 - 06/1996
Supra ECU Part Numbers (5spd, USDM, NA)
- 89661-14590 05/1993 - 06/1996
Supra ECU Part Numbers (Auto, US Spec, TT):
- 89661-14710 (1996.01-1996.08)
JDM
- 89661-14511 FS Auto TT ecu?
SC300
SC300 ECU Part Numbers (5spd, USDM)
- 89661-24321 (01/1992 - 07/1993)
ARISTO
Aristo ECU Part Numbers:
Aristo ECU (JZS16#)
Aristo ECU (Unknown Configuration)
-89661-30510 = JZS147..Q Oct 91 - Aug 93
-89661-30750 = JZS147..Q Aug 93 - Aug 95
-89661-30880 = JZS147..Q Jul 94 - Feb 95
-89661-3A180 = JZS147..Q Aug 95 on
-89661-30560 = JZS147, TT, ..V Oct 91 - Aug 93
-89661-30870 = JZS147, TT, ..V Aug 93 on
Additional notes:
jzs=Aristo
I have a 93.5 TT auto supra with ECU:
89661-14510
Discussion Starter · #13 · (Edited)
This is a running list of OEM ECUs designed to run the 2JZ-GE and 2JZ-GTE engines. Please include yours. Thank you to everyone that has contributed.
SUPRA MKIV
USDM
Supra ECU Part Numbers (Auto, USDM, TT)
-89661-14510 Year: 1993.5
JDM
SC300
ARISTO
Aristo ECU (JZS16#)
Additional notes:
jzs=Aristo
I don't know for sure, but according to the pattern of the list I would bet that it is an SC300 ECU.
Part 89661-24350 (COMPUTER, ENGINE CONTROL) was found on the following models:
08/1991-12/1993 JZZ31L-ACPVFA USA, 2JZGE, ATM, 4FC SC300
Which one of these are for the VVTI with auto?
Anyone have a 14590 for sale?
Adding another USDM 6spd ECU part # to the list 89661-14521.
Toyota system states this is part is for 94-96. Curious if anyone with 97-98 6spd owners can confirm.
1 - 20 of 30 Posts
