1 - 4 of 4 Posts
A friend of mine has a 85' supra and she needs help locating the ecu. I haven't seen the car so I have no clue, and I figured what better people to ask than you guys! My MKiii has the ecu above the glove box, is it the same on the mkii? Thanks
ecu
there are four screws that hold on the glove box door, take these out and remove the door, after that there are two screws on the glove box door latch, remove these and then locate two or three more screws in the vacinity of the latch.....remove all of them and then slide the glove box out.....With the box out look up and you'll see that little box of perfection shining right down on a ya.....easy work!!!!
1 - 4 of 4 Posts
