1 - 9 of 9 Posts
I am installing a Greddy turbo timer and one of the wires need to go to the speed sensor. I believe that goes into the ecu. Where is the ecu in the car and is there a better location to connect the speed wire for the turbo timer?
ƒ=1/2π(√k/m)
Your harness, or timer, should have come with a schematic of where your (rev sensor, or speed sensor is) you may need to splice.
No One Ever Listens To Me
hmmm you should just be able to wire it into your ignition harness.....but i dont know much about the greddy turbo timers.....but yes the ecu is behind and above the glovebox...remove glovebox and remove the black panel.....walla! :)
Thanks Bishop, that answered my question with that picture. I have everything connected and working fine, just need that last wire connected to make use of some of the features.
1 - 9 of 9 Posts
