·Okay, so I ordered the EGR block about a week ago.. and since I am putting on my DP in the next few days I decied to get around to isntall it...
Well to those that have not attempted this mod.. take hied... because this is a load of BS.... I mean dont get me wrong.. the parts are good and the mod is a good mod, but the install is such a biatch...
First off... to get this done correctly you need to remove the intake manifold. The first piece you need to remove is fairly easy since it is right on top.... but when you need to get to the second flange.. forget about it... unless you have miget hands, there is no way you are fitting your hands in there or fitting any type of usefull tool in there
So what I did was remove the first part... put the plate over it and then put the EGR valve back on it.... plug up all the hoses and leave the sensor pluged in...
My theory is this... even though the exhaust will come into that area, it wont get into the manifold.. so problem solved...
Anyone had advice on how to get to the second flange???
btw guys, this is my opinion and my experience.... take it as you may...
