1 - 15 of 15 Posts
For those of your wanting to block off the EGR exhaust port on the back of the head, I found that the steel plate on the block behind the oil filter fits the back of the head perfectly. Part # 11494-45010. $4.53 from Jay Mark's. I just cut out a gasket from a sheet of hi-temp Mr. Gasket material I had laying around. The JDM blockoff part number appears to be invalid, but this plate seems to work fine.
Dale H
87T
Moderators please delete thread!
Sorry for the wrong information guys, but I just checked both plates and the one Jay Mark's sent me fits the EGR port, but does not fit the spot behind the filter. Now I am confused because the Part Number they sent me is # 11494-45010. Weird.
Dale H
87T
Bishop,
Well, what I'm saying is I think it is just a fluke that I got what appears to be a JDM blockoff plate. I called Jay Mark's and ordered a part #25615-43020 (along with a bunch of other stuff), which is the JDM EGR blcokoff plate. I got a call back and they told me that the number for the JDM plate is no longer valid. Then when the package showed up with my other stuff, there was a plate in there that fits the EGR. However, it was listed on the invoice as a part #11494-45010, which is the blockoff plate behind the oil filter. But I looked at the plate behind the oil filter last night and it isn't the same size as the one Jay Mark's sent me. The oil blockoff plate that was on my engine won't fit over the EGR port like this mysterious plate Jay Mark's sent me does.
Dale H
87T
What if you just turn the egr valve around then put it back in? and for the othe rtwo smaller ports, just cut off the pipe part of the flange, then weld in a piece of metal over the hole?
I just made one out of a bit of 1/4" aluminum plate, took ten minutes with a blunt hacksaw and a power drill and it was free! Used the EGR cooler as a template.
yeah thats me!
i removed my egr, and my engine is out, should i go ahead and remove the cooler that is on the back as well? or can I just block off those two ports and be fine?
cassio
good info man, but i was under the impression the EGR works to help keep pinging down and for smog, so why block it off for? aight peace :chicken:
okay the egr exhaust gas recirculation
what does your tailpipe look like? black!
do you want that in your intake ? to imped flow and build up making your ports smaller and smaller ?
i just tore down a 5.0 mustang block with egr that the ports were so clogged that out of a quarter sized hole i couldn't fit an ink pen inside..
Bill
The Beginning
Sooo, you guys are saying not to block off EGR, or is it a good thing. Like say you leave the EGR cooler located at the back of the head but you block off the EGR valve from side of head and side of Intake Manifold, would you benefit from that?
VIPER HUNTER
The egr works at part throttle shuts at full throttle.It heats the intake manifold with the gas from the exhaust,and also coats the inside of the manifold with carbon over time.
I bypassed mine,160 thermostat,and passed emissions taking though a acually emission station.I swaped on the cat for the day.
The cooler plate on the back can be left there,you can block off the ports on the side of the head,and intake manifold.
It might help you alittle..less heating of the intake while driving normal..so you will have a cooler intake charge when you lean in it
1 - 15 of 15 Posts
