1 - 9 of 9 Posts
Okay...
How in the hell do you get to the bolts holding on the EGR pipe under the intake? I can barely see the top one, much less try and get a tool in there to break them loose. Am I going to need a lift to get under there?
Also, do you just cap off the upper vacuum lines going to the EGR valve?
Supraforums Member
I did my blockoff plates back in December and the lower Port is a real bitch. I would first build a set of extensions until I felt it lock onto the bolt. Then attach the ratchet and do your best. It takes a while but it can be done. Just try to be patient.
easiest way is to pull the manifold if you ask me. i could never figure out how u guys do it with out pulling the manifold.
i always say toyota !
you can just block either one and you are good. if you need to remove the EGR system then you need to block both ports. good luck.
I pulled the upper half of the manifold on my old car, alot easier. I lucked out on the car I have now, it was already done when I bought it.
I used an extension and a swivel, and it really wasn’t all that bad. As for the vacuum line I left the top part for the EGR system on, and caped that open vacuum lines. Hope this helps
Discussion Starter #8
Thanks for the tips guys... I will give it a shot again next weekend.
Fast Enough, Never Is.
I just took my intake manifold off when I did my fuel system and AEM, while the manifold was at the machine shop I had my welder weld shut the hole for the EGR. I had the plates but I thought it would be easy to do it that way also.
1 - 9 of 9 Posts
