1 - 1 of 1 Posts
ok here is my problem
Failed emission
real hi NOx 2354 instead of limit 1167
check EGR actually I bought a brand new one from Toyota $154
i did the vaccum test pass
I started the car with the EGR valve removed to see if the exhuast port for egr is clog its not
clean lil pipe from the EGR valve to the intake thats fine
put everything together
try sucking on the vaccum line going to the EGR while the car is at idle
it doesnt do anything, no stall no studder nothing
so went through emission again with new valve only brought it down by 54 points
what should i do New working EGR just dont work on the car
thank you for your time guys
even check the lil VSV solenoid for EGR valve
1 - 1 of 1 Posts
