Just wondering what people's EGT pre turbo is. Mine is about 1200F. on the highway.
Interesting theory, but there shouldn't be more then one fuel injector open at any given time, right? So even if there was a pressure drop when one injector opened, the pressure would go right back up as soon as that injector closed, a split second before the next opened. I'm not so sure the injector at the end of the rail would have any less pressure available for it's use. The regulator and pump(s) shouldn't have a problem keeping up anyway in a healthy fuel system. Or am I wrong?BPU+ Justin said:i have mine in the last cyl to get fuel since it should be the first to lean out and the first to have higher egts
Espeefan said:Interesting theory, but there shouldn't be more then one fuel injector open at any given time, right? So even if there was a pressure drop when one injector opened, the pressure would go right back up as soon as that injector closed, a split second before the next opened. I'm not so sure the injector at the end of the rail would have any less pressure available for it's use. The regulator and pump(s) shouldn't have a problem keeping up anyway in a healthy fuel system. Or am I wrong?
