1 - 8 of 8 Posts
What are safe EGTs to be running?
What egt's are members running? Idle? Cruising at 55mph-70mph? 2000-2500rpms? etc.?
Malik
Malik
My egt at 120km/h cruising: 700-730
wot:830-850
yesterday in 4th gear (wot 1,35bar) over 870
Don't know if these values are safe, they seems a bit high to me
All values in Celcius!
when this baby hits 88mph
wot:830-850
not terrible, but a little high.
i usually shoot for a max of 825-850C. 900C is the danger things are gonna melt point.
might want to check your a/f and timing.
Discussion Starter #6
Egt
My sensor is located on the turbo elbow.
I'm seeing right around 500 - 620 degrees celsius cruising at 70-8omph!
I'm going to Dyno tune on Wed. After which I'll be able to post some proper numbers.
9,000,000 lbs of BOOOOST!
melting point of aluminum is about 1,200 deg F just keep that in mind. Id say a "safe" EGT under boost would be betwen 12-14 deg F (x100)
1 - 8 of 8 Posts
