Eibach lowering springs
Drag_on Supra
I had my Eibachs (and Bilsteins) installed on my Mkiv about 3 weeks ago, and it took almost exactly 4 hours. I was with the guy the whole time so i know that's how long it took.
This guy has done several Supras before, so knew what he was doing, but any other garage should be able to do it in similar time.
6 hours just for the fronts is a total rip-off. we did 4 springs, and 4 shock absorbers in 4 hours !
Also, to confirm on the product codes for the Eibachs, (as this has caused some confusion over here in the UK) :
The BOX code for the Eibach pro-kit springs for Supra = 8222.140
This kit consists of 2 front springs and 2 rear springs (obviously)
The FRONT SPRING code = 8222.001
The REAR SPRING code = 8222.002
These spring codes will be stamped on the actual Eibach spring itself. So that's the easy way to tell that the 8222.001 spring goes on the front and the 8222.002 spring goes on the rear.
Also, the front will be lowered about 1.5 inches and the rear about 1 inch (compared to stock ride height).
I'm very pleased with the result. The ride is perhaps a little jiggly now but the car feels very well controlled now during fast driving.
