Does anyone know what the part number is for the Eibach front springs vs the rear springs? I seriously doubt this is the problem (the springs being installed on the wrong end of the car), but the front of the car seems to be about 1/4-1/2" to low. It may be a descrepancy in the AGX shocks (being shorter than stock or having a lower spring perch), but I thought I would check anyway. Basically the front tire rubs the upper fender liner while cornering hard and when entering a driveway at an angle. I have installed some TRD swaybars and they have pretty much eliminated the rubbing while cornering, but they still rub over a bump if hit at an angle. This is with the same size/offset wheel and tire I ran on the front of my other car at the roadcourse and smaller than the setup I used on the street. I never had any issues with the other car rubbing. This is what leaves me to believe that either the shocks/springs have been installed incorrectly (slim chance) or that the specs on the shock length or spring perch on the AGX's is a little lower than stock shocks.
Any input would greatly be appriciated. I don't want to go with coilover because the spring rates are just to high for a daily driver. And I really don't want to spend the extra money to change to the Koni's (with the adjustable spring perch), because the Eibach/AGX setup should work fine for my needs and shouldn't rub.
Thanks again, Steve
Thanks again, Steve
