1 - 2 of 2 Posts
I put up BS Flags
Hey guys,
I am on Spring Break this week and i am installing my electric fan kit. Well i pretty much have the fan mounted and everything the problem is in the wiring. Everything is ok and I got a kit to turn the fan on at 185 degrees OR when the AC kicks on. The problem is in the AC wiring. I need to know where the AC clutch cable is. I need this wire to run to this cable so that when i turn on my AC the fans automattcally turn on but i only have a general idea where it is. Everything else works well i just need to find out where to run that cable off the AC clutch. No test drive yet really bad weather at the moment and i would prefer to have the AC cable run first. If anyone has any idea where i need to run this wire i would appreciate it.
Thanks,
I put up BS Flags
Discussion Starter · #2 ·
bump
1 - 2 of 2 Posts
