Bishop92T said:
I saw some old flow charts, I forget where. Once you get up to speed a fan in front of the radiator will only be a restriction no matter if it's on or not. A fan behind will be much less of a restriction. We're talking real world results here, not results from a laboratory. How about some proof from your argument?
Flow charts: every decent fan comes with one (funny, automotive aftermarket cooling fans almost NEVER include one, hmmm). However notice all the flow charts are for intake or exhaust configuration (push or pull). If there was a difference wouldn't we need two separate flow charts? Of course we would.
The flow charts are "real world conditions" test results, obtained by measuring a real fan. Most fans are measured like this:
Measurement of Fans Link
I was going to type up a big breakdown of how this works, by braking down airflow into it's components, so the results would be obvious, but this is just silly.
Unfortunately this is a field that isn't covered very well on the internet, so I cannot link to a website titled "www.the_facts_of_radiator_ cooling_fans.com"
Let's just say, whatever flows INTO the radiator, must also flow OUT OF the radiator.
Correct?
If you restrict the exhaust of the radiator, then air cannot flow into it.
If you restrict the intake, more air cannot exhaust than went in, right?
______________________________
>>>>>>Quick and dirty example number one:
Think of air flow as bunch of ping-pong balls. 10 ping-pong balls go into the radiator, 10 have to come out, during a certain time period, let's say 1 second.
Now restrict the intake to the radiator, so only 5 ping-pong balls can get in (in one second), and only 5 will come out. We just halfed the airlfow volume!
Now move the restriction from the description above, to the exhaust side of the radiator. How many ping-pong balls will go through?
5 of course.
>>>>>>>>>Second quick and dirty example:
Let's say I told you that you have to breathe through a drinking straw for a 5 minute period.
I give you a choice however that, you can freely inhale or exhale without using the drinking straw.
What would you choose?
1) Inhale: no straw.....................Exhale: through the straw
2) Inhale: through the straw.......Exhale: without the drinking straw.
In which situation could you breathe more air?
Answer?....... It doesn't matter, they are the same. What goes in, must come out. Doesn't matter which is restricted.
________________________________________
Primary cooling fans are characteristically pullers, by default. Show me a list of vehicles that use pushers instead.
He he, the reason is very simple. There is almost never room IN FRONT of the radiator to install suitably large "pusher" fans. And any mechanical fan, driven by the engine has to be a puller, for obvious reasons.
The difference in performance is minimal, compared to the challenge of mounting the fans up front.
Cheers...........eggnog is kicking in, right about now
..Sdude.
