How doo you wire electric fans into a aem? to control them?
reason i ask i do no have room for stock clutch fan being its swapped.
thanks
thanks
That I don't like. I would be nervous as to what would happen on a really hot day.my electric fans work very well, I even road race with them. I do run warmer at idle however.
Ive actually heard of some guys cars overheating, and blaming it on the fans...only to find out they had them blowing in the wrong direction:lol:That I don't like. I would be nervous as to what would happen on a really hot day.
The pitch on the stock fan blades is something a lot of people don't consider.
Lol I guess you really could sit there and ponder for a minute if you want the fans to blow air on the engine, or suck the air out of the car, which would be funny if you were driving, and all of the air that the fans was pulling out of the car would simply be hitting the car again. Kind of like spitting in the wind:biggrin:Ive actually heard of some guys cars overheating, and blaming it on the fans...only to find out they had them blowing in the wrong direction:lol:
I don't think anyone would disagree that when the car is going down the highway the fans work fine, but have you sat in dead stop rush hour traffic for long periods of time when the temp was over 100 degrees? What does the temp get up to then?I have road raced my car in 100+ degree heat with the electric fans and did not over heat.
I can contest to say that I have sat at shows and on the street for hours waiting with the A/C CRANKING and it being so hot it hurts breath and I have only had a problem with the fan when I forgot to turn it onI don't think anyone would disagree that when the car is going down the highway the fans work fine, but have you sat in dead stop rush hour traffic for long periods of time when the temp was over 100 degrees? What does the temp get up to then?
Or you could just have it come on with the ignition.well guys thanks for all the responses yea i looked int oa hydro fan setup and considered it... one thing i noticed with fans was i had a 14 inch fan that moved 1800cfm and now i have 2 8 inch fans that flow 2100cfm each. and a shroud and so far it helped out alot i just want aem to control them or put in a aftermarket thermoswitch to control them.
^ what CFM are they?Run the fans off a GS300 or IS300 with the 2jz in it. They work great.
It gets a bit warmer that it did with the stock fan, which was about 170-175 to about 185-190. I did see water temps reach 195 once.
You have to remember I am running a modified AAP shroud with upgraded fans, not the ones the unit shipped with.
