got boost???
went to install my water temp, oil pressure gauge, boost guage....got everything wired up and put everything back together...gauges work fine...BUT he light doesn't turn on? also the dash lights are out...and climate control have no back light when headlights are on...when its off then climate has light? i wired the two gauge lights to the cigratte lighter and wired another one to another power and ground. checked the gauge fuse, tail fuse and nothing is blown...would this be my dimmer switch getting fried? or something else?
also if its the dimmer switch would a 87 NA switch fit a 89 turbo one?
thanks
Check your fuses first. With all the stuff that is out it sounds like everything is hooked up right, but a fuse or relay blew.
got boost???
i checked all fuses in the kick panel and seems like eveyrthing is not blown...so ?
got boost???
alrite guys it was the dimmer switch...i jumped the W-G and W-B wire and everything was lit up....i had to go take one from my frineds parts car and it worked....THANKS
