1 - 9 of 9 Posts
Hello,
I need the pinouts, function, and wire colors for the 24 pin ecu
connector and the 14pin body connector that has the starter signal (big
spade), etc on it.
I dont have an electrical book here, just the crappy service manual.
I also have a mystery mk2 connector that I have no idea what it does.
Its right near the battery, 4 wires, 2 are pink (I forget the tracer
color), but it was badly corroded and one termincal broke off. We
think it's for some kind of headlight thing. Does this ring a bell?
Later
"I dont have an electrical book here, just the crappy service manual."
What's on the website, is what I have, the factory service manual. I need more info than that. The info they give you is useless. I need info like "on connector X, pin 2, is the main relay in"
OK i've got info for the 24 pin connector.
Pin # Color Function
1 Light green w/ blue stripe Goes to ECU-IG 15A fuse
2 Green w/ white stripe Goes to 15A STOP fuse
3 Blue w/ Red stipe Goes to Pin 4 of AFM
4 Yellow w/ Blue stripe Goes to Pin 6 of AFM
5 Yellow w/ Black stripe Goes to pin 7 of AFM
6 N/A blank (if automatic) Goes to ECT
7 Blue w/white stripe Goes to speed sensor in gauge cluster
8 N/A blank
9 Red w/ yellow stripe Goes to Pin 4 of COR (circuit opening Relay)
10 N/A Blank
11 N/A blank
12 Tan Goes to 02 sensor
13 Black w/ yellow stripe Goes to charge warning lamp & Pin 1 of ISCV
14 Black w/yellow stripe Same as Pin 13 function
15 N/A blank
16 N/A blank
17 N/A blank (If automatic) Goes to ECT
18 Yellow w/ Black stripe Goes to Oil Pressure sender
19 Blue w/ Red Stripe Check engine light
20 Black w/ White stripe Goes to A/C compressor
21 N/A blank
22 N/A blank (If automatic) goes to ECT
23 Grey w/ Brown dots 02 Sensor?
24 Brown w/ Black dots Goes to Pin 3 and Pin 5 of AFM
HTH.. i'll see what i can do about the body connector
The 14 pin connector depends on what year the vehicle is. So what year is your car?
1 - 9 of 9 Posts
