1 - 4 of 4 Posts
My battery is still not getting charged. I have:
- taken the alternator to get it tested (OK)
- replaced the 14GA fusible link in the fuse box
- checked for continuity from the alternator connections to their respective destinations (OK)
- checked for continuity from alternator connections to ground (OK)
- replaced connections to battery
- battery has been bought 4 months ago, did not get it tested.
- measured amperage between charge fuse contacts (0 Amp)
I really have no idea where to go from here, any suggestions at all would be wonderfull.
Over 10 years on SF....
Get the battery tested, might as well! I bought a battery that wouldn't hold a charge for shit! That or sand off the terminals ect ect. Other then that sounds like a mystery.
Oh, I forgot to add that whenever I did some serious troubleshooting and moved cables around it would work... up until the point where I gave the gas hardcore. I haven't been able to get it to do that at all lately.
It's not even getting charged, which is what the amperage test across the charge fuse contacts showed.
1 - 4 of 4 Posts
