1 - 11 of 11 Posts
Dr Wheelspin Rh.D.
You didn't put much thought into that question did you? If your car didn't come with one, and it runs then it's pretty obvious that you don't need it.
BTW I think you are referring to the HAC sensor (High Altitude Compensation).
Republican
Ya, n/a's dont have one... I wonder what the ecu adjusts, in response to the high altitude compensation sensor....
It changes the correction factor for air density, which is used to determine the mass flow rate in the alogithm used to calculate injector pulse width.
Republican
Oh, thats exactly what I was thinking....:wtf: :scratch: :confused: haha, well thank you for the answer...
Back to Action!
It wasn't so much not enough thought as it was poorly worded. My car is/was an '87 NA (as such no HAC). We're in the process of doing the GTE swap. So the question is, will the car run w/o the HAC?
BTW I think you are referring to the HAC sensor (High Altitude Compensation). [/B]
Having read up some more on it, thats exactly what I was talking about.
Yes, use the HAC. I was installing my S-AFC this weekend and I could have sworn I saw the thing mounted behind the glovebox (near the ECU) on my 88T.
1 - 11 of 11 Posts
