Hey guys, I need some help ASAP to pass aircare (live in canada, BC)
Car:
93.5 tt, single turbo, 3400 stall, map ecu, stock injectors, fmic...reinstalled factory cats.
Max allowable:
HC = 0.5000
CO = 9.3200
NOx = 1.2400
Test 1 - 94 chevron octane, single turbo setup remained same
HC = 1.1915 (failed)
CO = 7.4809 (pass)
NOx = 0.3269 (pass)
Test 2 - 94 chevron octane, some methohydrate, single turbo setup same
HC = 1.3934 (failed)
CO = 6.5163 (pass)
NOx = 0.4058 (pass)
Test 3 - 94 chevron octane with MoHawk 94, removed map ecu, installed stock MAF, IAT sensor was still intact as its connected to the wired from maf, so i left it
HC = 0.5070 (failed by .0070)
CO = 1.2838 (pass)
NOx = 3.1272 (failed)
As you can tell the first 2 tests HC didnt come close to passing, but in the third test it almost did. On the chart, HC was only high during the 100 k/m run on the third run.
But NOx failed horribly after te stock maf was installed. I did notice when i woudl go into any boost my wideband would read 17+, so it was leaning out for some reason.
Any suggestions, i need to pass by saturday.
Car:
Max allowable:
HC = 0.5000
CO = 9.3200
NOx = 1.2400
CO = 7.4809 (pass)
NOx = 0.3269 (pass)
CO = 6.5163 (pass)
NOx = 0.4058 (pass)
CO = 1.2838 (pass)
