1 - 20 of 41 Posts
These are 4 months old, but I havn't changed much...
Finally got the engine, bodywork, and suspension totally re-done, and corrected every mistake made during the initial conversion.......Only a 2-yr project.... :ugh2:
Anyway, making 610 hp @ 20psi on pump 93, PTE67/81, 272/264 cams, AEM, outside temp 99 degrees, 94% humidity...... :)
Thanks Alamo Motorsports!! :bigthumb:
'93 Supra TT
clean setup. very nice man, i like it
A right, not a privilege
Beautiful.
wow that is so sick, WOW nicley done.
Wholesome creamy goodness
Very nicely done! Who made the custom shroud?
BOOST ALMIGHTY said:
Who made that Custom Shroud for you? It looks awesome.
Im curious as well...who made it...do tell! I am in Texas as well, and would LOVE to have one made for me, if possible.
[email protected]
Can you give me some details and good pictures of the boxes on the left and right? Assumably battery box and air intake box?
Discussion Starter · #19 ·
brian94ht said:
Just curious, what happens to that hardpipe with wiggins clamps between the motor and the radiator when the engine twists under torque?
Wiggins clamps have a small tolerance of movement. Never seen a drop of water or steam out of that one. :)
The clamp on the INTAKE side however---- had to be realigned a couple of times, (and replaced once $$$) due to the original install being misaligned.
Discussion Starter · #20 · (Edited)
One on the left is the intake cold air box. The one on the right holds the fuse-relay box and misc. electronics. The batteries (twin Genesis 680 amp) are mounted in the rear seat cushion locations, under the rear seat delete panels.
1 - 20 of 41 Posts
