·I have the following questions about engine compression, see if anyone can help me out here:
according to supra repair manual, difference between each cylinder shouldnt be more than 14psi. does that mean all 6 cylinders should be within 14psi difference?
also, how much HP would the engine loose if all 5 cylinders are in good condition except 1?
Lastly, according repair manual, I should also disconnect Camshaft position sensor...but its a PIA to reach it, would it effect the result if I were to leave it connected?
going to check mine soon, hope everything works out.
thanx
Jonas
thanx
Jonas
