1 - 8 of 8 Posts
my engine light comes on once in a while when driving and when i check codes it gives me a code 32 i think the knock sensor code but the when i turn the car off and start her up again the engine light is no more plus it does not effect the performance in any way so just wondering do i need to replace my knock sensors or is it a wiring issue if it is the sensors i know there is 2 of them but i dont know where?
any advice guys
Thanks.
code 32 is the HAC sensor. just do a quick search and you will find some things on it.
slowly giving up...
code 52 is the KS code. if your KS(s) are acting up, or more likely the wiring, then your car will not perform up to spec.
-shaeff
it only lights up once in awhile and if it is the wiring how would i go around fixing this problem?
Thanks.
i had the same problem. does your turbo choke? or struggles while driving like not enough air is getting through? i found out my negative bolt on my battery wasnt tight enough. tighten it up and supra running great. check it out.
my check light goes on and off too,checked and code 52 also came out(knock sensors)but does not affect performance of my car in any way,should i repace em as this might lead to serious problems down road? ty
1 - 8 of 8 Posts
