1 - 11 of 11 Posts
What type of paints have you guys used to paint engine parts? I'll be reassembling my block soon and would like to paint a few things (powdercoating is not an option, you won't be talking me into it =P). Namely the valve covers, block, a few brackets here and there... I don't want something that will flake off like I've heard of some paints doing. Is clear coating a good idea? What have your experiences been?
Digital Dreamer
How much does powdercoating actually cost anyways? I know at Canadian Tire they sell spray paints that are high temp I used some on my calipers and they lasted a long time.
eric
Republican
Powdercoating is the way to go... I use black semi gloss krylon for my pulley's though
I paid 10 dollars to get my 3rd valve cover powdercoated.
I used high temp paint from schucks. Check out the finish.
Costs about $15 after primer and paint. The key like in painting anything else is the prep work. The job will only look as good as the prep work, I.E. taping everything off and cleaning everything extremely well. The paint was a well known brand and is good to 1200 degrees. HTH.
Seth
Gorgeous block! I was going to try red but the way your block looks has me wanting to change my mind :) What kind of prep work aside from thorough cleaning did you do? Any sanding? The block will have been hot tanked 3 times by the time I get it back so hopefully that will be enough. How many coats of primer/paint? Thanks for the response, definitely helping!
didn't sand the block down did ya? i see the roughness showing on the paint. I did my block like this, took about 6 hours of my time but it was well worth it, then the two coats of paint and it looks almost flawless.. but i can live with it ;)
TheFastCoonAss
1 - 11 of 11 Posts
