1 - 16 of 16 Posts
I know that they are M10 X 1.25 at 120MM long. My problem is I can not find any place that sells then let along sells them in singles. My local Home Depot has the size but not the length. Does anybody have any then want to sell or lend to me for a little bit or know where I can order some??????
Thanks,
Bobby
oooh well i got some good news and bad news.
Fastenal sells them.
The bad news is you have to buy 50 at time....
ask oneandgone as he was selling them because i needed some and he bought all 50. Though i think he might have sold out as it turns out more than a few folks needed them. LOL. If he does not have any.. Contact me. I might have a set for you. ;)
Supranian
I bought mine at OSH (Orchard Supply Hardware). Home Depot sucks anyway.
I tried Fastenal too but I didn't want a bulk and I would use the tranny bolts but they are too short for the arms I am using on my engine stand. I would do longer ones and cut them down but I still can't find them.
figgie you have a PM
92 TURBO
"Home Depot sucks anyway".
^ So true. Totally useless " Home Dumpo" wouldn't have the grade bolts you'd need anyways. The hardware sold at the "Dumpo" is all low grade cheap shit that's made in Mexico, Tawain that would break if you torqued it past 20 ft/lbs.
I would use at LEAST a metric class 7T (3 lines on the head in a "Y") or higher grade bolt unless you want your engine on the ground. Go to a good automotive or specialty hardware store. < this excludes Auto zone, Pep boys, Advance auto and all the other big chain auto stores that sell their hardware in blister card packs.
~ mike
Discussion Starter · #10 ·
I got a buddy who is looking for me right now. If not I'll probally get a box from Fastenall and charge it to the company :D
Discussion Starter · #11 ·
Problem solved Bugwugger hooked me up with some bolts thanks for the replys though
92 TURBO
Thanks,
Bobby
^ I ordered 4 bolts from my Toyota dealer #90105-10038 @ $1.55 ea. I had them the next day. They are a class 7T and it's the bolt used for the bottom bracket for the p/s pump to pivot on. Worked perfectly for me and was the correct length for the arms on my engine stand as the 4 tranny bolts were too short for my stand.
~ mike
EDIT here's the link:http://www.cygnusx1.net/supra/library/EPC/MKIII_NATO/291420/4503_1.html
^ It's the bolt at the bottom of the pump right above the pic of the 44443 bracket
No One Ever Listens To Me
SupraMikeCT said:
^ Not long enough for my engine stand mounts.
ummmmmmm thats weird because every single engine ive put on my engne stand...which would be about 9 of them now.... ive used tranny bolts and it holds it perfectly....
Discussion Starter · #15 ·
its probally my stand thats screwed up I will try the PS bolts since Mark hasn't called me back yet. CALL ME MARK!!!
92 TURBO
^ BUT, the stock tranny bolts measure 2 1/4" long from under the captive washer, my engine stand mounting arms are 2 5/8" thick (made with welded on spacers on the arms to allow for additional room to work on the rear of engine while mounted on the stand) and the p/s pump pivot bolt is 3 5/8" long which worked perfectly for my stand with just 1 washer added under the bolt head. They were $1.55 (my price) each from the Toyota dealer and the best part is you can buy just the 4 that you'll need.
~ mike
1 - 16 of 16 Posts
